Dummy001
Jul 05, 2026Tutor
No VPN?
Router is a new RS100. I've been all over the Advanced set up page and cannot find where to set up a VPN. I'm just starting to dabble into this and would like the router for my VPN, for now. Any idea...
HappyCat
Jul 05, 2026Virtuoso
The bottom item under Services and Security:
Of course, not actually having an RS100, it is somewhat of a stretch to infer that the Product Data Sheet is accurate. Every Netgear WiFi router has had OpenVPN as part of the firmware for over a decade.
- StephenBJul 05, 2026Guru - Experienced User
So "Host Mode" is just what you chose to call it.
Every Nighthawk and Orbi. But the manual for the RS100 doesn't include include it, and Dummy001 can't find the configuration for it. So I am thinking that this Nighthawk doesn't have it.
FWIW, the manual does include DDNS.
- Dummy001Jul 05, 2026Tutor
For reference, here are the menus straight from the router.
No reference to "setting up" a VPN, just that it supports it. So, I'm thinking I would need to use an add on VPN app/program. BTW - I'm on Linux Mint.
