fbeinfo
Nov 25, 2024Guide
no WWW access after 24 hours and only on one client in the NETWORK - NETGEAR RS200
Hi all Here my Router data first Hardware Version RS200 Firmware Version V1.0.1.60 GUI Language Version V1.0.0.449 Protection Engine Version 2.2.214.4/1.0.0.2061 O...
Nov 25, 2024Guru - Experienced User
If it's only the one PC, and nothing else sees this issue, you'll need to take a closer look at the PC.
Check wired vs wireless connections.
Be sure all ethernet and wireless adapter drivers are updated from there Mfr.
Contact the PCs mfr for help and support information regarding there product.
