Gatorproof
Mar 08, 2025Follower
node compatibility
upgrading to a rs100 from mr60. will the mr60 nodes work? thanks
No.
Nodes? You mean satelllites? If so, then No is the answer.
What you can do is put the MR60 router into access point mode and connect that to the RS100. You can then connect the MS60 satellites to the MR60.
You can then end up with a messy wifi environment as the MK6X's network fights the RS100 network.
Disclaimer: Just another user with time on their hands.
