X5-2024
Dec 19, 2024Aspirant
OpenVPN 2.6.12-1001 not working on Windows 11
Having a frustrating time getting OpenVPN working with my Nighthawk RS300 router on Windows 11. I have followed the install instructions from the Netgear website, including: - Changing network a...
Dec 20, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is Protection Engine enabled on the RS router? Try disabling it and see?
Check with OpenVPN support for help and information regarding there product...
- X5-2024Dec 20, 2024Aspirant
Thanks for your reply.
The modem (set to pass through) is the Xfinity XB6. I'm using Cat 6e cable. I don't believe the issue is at this end as I can access the Netgear router and host computer from my android phone (outside of the network).
I have tried disabling the Protection Engine. No luck here.
I believe the issue is in the Config file for Windows.
- FURRYe38Dec 20, 2024Guru - Experienced User
Is Windows the only one PC you have? Don't happen to have a different PC to test with?
Have you asked OpenVPN about this issue with Windows 11?
https://forums.openvpn.net/viewtopic.php?t=33940
https://geekchamp.com/how-to-fix-openvpn-not-working-in-windows-11/
