X5-2024
Dec 19, 2024Aspirant
OpenVPN 2.6.12-1001 not working on Windows 11
Having a frustrating time getting OpenVPN working with my Nighthawk RS300 router on Windows 11. I have followed the install instructions from the Netgear website, including: - Changing network a...
X5-2024
Dec 20, 2024Aspirant
Thanks for your reply.
The modem (set to pass through) is the Xfinity XB6. I'm using Cat 6e cable. I don't believe the issue is at this end as I can access the Netgear router and host computer from my android phone (outside of the network).
I have tried disabling the Protection Engine. No luck here.
I believe the issue is in the Config file for Windows.
Dec 20, 2024Guru - Experienced User
Is Windows the only one PC you have? Don't happen to have a different PC to test with?
Have you asked OpenVPN about this issue with Windows 11?
https://forums.openvpn.net/viewtopic.php?t=33940
https://geekchamp.com/how-to-fix-openvpn-not-working-in-windows-11/
