KngDa
Nov 10, 2025Aspirant
OpenVPN connects to router when clients on Ethernet but not on Wifi
I am having difficulty getting OpenVPN to work to connect to my RS300 router with my Windows 11 computers. I have a Dell XPS 16 9640 and a Microsoft Surface Pro 2103 both running Windows 11 Pro. Both...
- Dec 03, 2025
Without making any changes, the VPN connection now works over wi-fi on the Dell laptop. The only change was a firmware update from Dell including for the wi-fi adapter. I tried updating the firmware on the tablet, but the problem still persists on that computer. I will continue to look at the difference between the tunnels and see what the difference is and if I can override it.
CrimpOn
Nov 10, 2025Guru - Experienced User
I struggle with "Client" and "Remote".
Is this correct:
- The RS300 router is set up at the Remote location. (perhaps your home office)
- What is the primary IP subnet for the RS300?
- What IP subnet does the RS300 use for devices connected using OpenVPN?
- The Windows 11 laptops are located at the Client location (or at a public WiFi location).
- When the Windows 11 laptops are connected to the Client system using Ethernet, they receive a local IP address that is different from the IP subnet at the Remote location.
Over Ethernet, the laptops can connect to OpenVPN and "everything works". What is the IP address they receive from the RS300 when connected using Ethernet? - When the Windows 11 laptops are connected to the Client system using WiFi, they receive what IP address? What "router status" says the connection is successful? (are these tests being conducted with the Client and Remote networks physically in the same location?
I like to set the OpenVPN log file debugging option to 5. i.e. change
verb 0
to
verb 5
