KngDa
Nov 10, 2025Aspirant
OpenVPN connects to router when clients on Ethernet but not on Wifi
I am having difficulty getting OpenVPN to work to connect to my RS300 router with my Windows 11 computers. I have a Dell XPS 16 9640 and a Microsoft Surface Pro 2103 both running Windows 11 Pro. Both...
- Dec 03, 2025
Without making any changes, the VPN connection now works over wi-fi on the Dell laptop. The only change was a firmware update from Dell including for the wi-fi adapter. I tried updating the firmware on the tablet, but the problem still persists on that computer. I will continue to look at the difference between the tunnels and see what the difference is and if I can override it.
KngDa
2025-11-10 13:35:15 us=453000 pkcs11_pin_cache_period = -1
2025-11-10 13:35:15 us=453000 pkcs11_id = '[UNDEF]'
2025-11-10 13:35:15 us=453000 pkcs11_id_management = DISABLED
2025-11-10 13:35:15 us=453000 server_network = 0.0.0.0
2025-11-10 13:35:15 us=453000 server_netmask = 0.0.0.0
2025-11-10 13:35:15 us=453000 server_network_ipv6 = ::
2025-11-10 13:35:15 us=453000 server_netbits_ipv6 = 0
2025-11-10 13:35:15 us=453000 server_bridge_ip = 0.0.0.0
2025-11-10 13:35:15 us=453000 server_bridge_netmask = 0.0.0.0
2025-11-10 13:35:15 us=453000 server_bridge_pool_start = 0.0.0.0
2025-11-10 13:35:15 us=453000 server_bridge_pool_end = 0.0.0.0
2025-11-10 13:35:15 us=453000 ifconfig_pool_defined = DISABLED
2025-11-10 13:35:15 us=453000 ifconfig_pool_start = 0.0.0.0
2025-11-10 13:35:15 us=453000 ifconfig_pool_end = 0.0.0.0
2025-11-10 13:35:15 us=453000 ifconfig_pool_netmask = 0.0.0.0
2025-11-10 13:35:15 us=453000 ifconfig_pool_persist_filename = '[UNDEF]'
2025-11-10 13:35:15 us=453000 ifconfig_pool_persist_refresh_freq = 600
2025-11-10 13:35:15 us=453000 ifconfig_ipv6_pool_defined = DISABLED
2025-11-10 13:35:15 us=453000 ifconfig_ipv6_pool_base = ::
2025-11-10 13:35:15 us=453000 ifconfig_ipv6_pool_netbits = 0
2025-11-10 13:35:15 us=453000 n_bcast_buf = 256
2025-11-10 13:35:15 us=453000 tcp_queue_limit = 64
2025-11-10 13:35:15 us=453000 real_hash_size = 256
2025-11-10 13:35:15 us=453000 virtual_hash_size = 256
2025-11-10 13:35:15 us=453000 client_connect_script = '[UNDEF]'
2025-11-10 13:35:15 us=453000 learn_address_script = '[UNDEF]'
2025-11-10 13:35:15 us=453000 client_disconnect_script = '[UNDEF]'
2025-11-10 13:35:15 us=453000 client_crresponse_script = '[UNDEF]'
2025-11-10 13:35:15 us=453000 client_config_dir = '[UNDEF]'
2025-11-10 13:35:15 us=453000 ccd_exclusive = DISABLED
2025-11-10 13:35:15 us=453000 tmp_dir = 'C:\Users\theki\AppData\Local\Temp\'
2025-11-10 13:35:15 us=453000 push_ifconfig_defined = DISABLED
2025-11-10 13:35:15 us=453000 push_ifconfig_local = 0.0.0.0
2025-11-10 13:35:15 us=453000 push_ifconfig_remote_netmask = 0.0.0.0
2025-11-10 13:35:15 us=453000 push_ifconfig_ipv6_defined = DISABLED
2025-11-10 13:35:15 us=453000 push_ifconfig_ipv6_local = ::/0
2025-11-10 13:35:15 us=453000 push_ifconfig_ipv6_remote = ::
2025-11-10 13:35:15 us=453000 enable_c2c = DISABLED
2025-11-10 13:35:15 us=453000 duplicate_cn = DISABLED
2025-11-10 13:35:15 us=453000 cf_max = 0
2025-11-10 13:35:15 us=453000 cf_per = 0
2025-11-10 13:35:15 us=453000 cf_initial_max = 100
2025-11-10 13:35:15 us=453000 cf_initial_per = 10
2025-11-10 13:35:15 us=453000 max_clients = 1024
2025-11-10 13:35:15 us=453000 max_routes_per_client = 256
2025-11-10 13:35:15 us=453000 auth_user_pass_verify_script = '[UNDEF]'
2025-11-10 13:35:15 us=453000 auth_user_pass_verify_script_via_file = DISABLED
2025-11-10 13:35:15 us=453000 auth_token_generate = DISABLED
2025-11-10 13:35:15 us=453000 force_key_material_export = DISABLED
2025-11-10 13:35:15 us=453000 auth_token_lifetime = 0
2025-11-10 13:35:15 us=453000 auth_token_secret_file = '[UNDEF]'
2025-11-10 13:35:15 us=453000 vlan_tagging = DISABLED
2025-11-10 13:35:15 us=453000 vlan_accept = all
2025-11-10 13:35:15 us=453000 vlan_pvid = 1
2025-11-10 13:35:15 us=453000 client = ENABLED
2025-11-10 13:35:15 us=453000 pull = ENABLED
2025-11-10 13:35:15 us=453000 auth_user_pass_file = '[UNDEF]'
2025-11-10 13:35:15 us=453000 show_net_up = DISABLED
2025-11-10 13:35:15 us=453000 route_method = 3
2025-11-10 13:35:15 us=453000 block_outside_dns = DISABLED
2025-11-10 13:35:15 us=453000 ip_win32_defined = DISABLED
2025-11-10 13:35:15 us=453000 ip_win32_type = 3
2025-11-10 13:35:15 us=453000 dhcp_masq_offset = 0
2025-11-10 13:35:15 us=453000 dhcp_lease_time = 31536000
2025-11-10 13:35:15 us=453000 tap_sleep = 0
2025-11-10 13:35:15 us=453000 dhcp_options = 0x00000000
2025-11-10 13:35:15 us=453000 dhcp_renew = DISABLED
2025-11-10 13:35:15 us=453000 dhcp_pre_release = DISABLED
2025-11-10 13:35:15 us=453000 domain = '[UNDEF]'
2025-11-10 13:35:15 us=453000 netbios_scope = '[UNDEF]'
2025-11-10 13:35:15 us=453000 netbios_node_type = 0
2025-11-10 13:35:15 us=453000 disable_nbt = DISABLED
2025-11-10 13:35:15 us=453000 OpenVPN 2.6.14 [git:v2.6.14/f588592ee6c6323b] Windows [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] [DCO] built on Aug 6 2025
2025-11-10 13:35:15 us=453000 Windows version 10.0 (Windows 10 or greater), amd64 executable
2025-11-10 13:35:15 us=453000 library versions: OpenSSL 3.5.1 1 Jul 2025, LZO 2.10
2025-11-10 13:35:15 us=453000 DCO version: 1.3.3
2025-11-10 13:35:15 us=453000 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
2025-11-10 13:35:15 us=453000 Need hold release from management interface, waiting...
2025-11-10 13:35:15 us=906000 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:57560
2025-11-10 13:35:16 us=15000 MANAGEMENT: CMD 'state on'
2025-11-10 13:35:16 us=15000 MANAGEMENT: CMD 'log on all'
2025-11-10 13:35:16 us=93000 MANAGEMENT: CMD 'echo on all'
2025-11-10 13:35:16 us=93000 MANAGEMENT: CMD 'bytecount 5'
2025-11-10 13:35:16 us=93000 MANAGEMENT: CMD 'state'
2025-11-10 13:35:16 us=93000 MANAGEMENT: CMD 'hold off'
2025-11-10 13:35:16 us=93000 MANAGEMENT: CMD 'hold release'
2025-11-10 13:35:16 us=109000 LZO compression initializing
2025-11-10 13:35:16 us=109000 Control Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1250 tun_max_mtu:0 headroom:126 payload:1600 tailroom:126 ET:0 ]
2025-11-10 13:35:16 us=109000 MANAGEMENT: >STATE:1762806916,RESOLVE,,,,,,
2025-11-10 13:35:16 us=171000 Data Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1500 tun_max_mtu:1600 headroom:136 payload:1800 tailroom:568 ET:32 ]
2025-11-10 13:35:16 us=171000 TCP/UDP: Preserving recently used remote address: [AF_INET]XXX.XXX.246.109:12974
2025-11-10 13:35:16 us=171000 Socket Buffers: R=[65536->393216] S=[65536->393216]
2025-11-10 13:35:16 us=171000 UDPv4 link local: (not bound)
2025-11-10 13:35:16 us=171000 UDPv4 link remote: [AF_INET]XXX.XXX.246.109:12974
2025-11-10 13:35:16 us=171000 MANAGEMENT: >STATE:1762806916,WAIT,,,,,,
WR2025-11-10 13:35:16 us=234000 MANAGEMENT: >STATE:1762806916,AUTH,,,,,,
2025-11-10 13:35:16 us=234000 TLS: Initial packet from [AF_INET]XXX.XXX.246.109:12974, sid=6a27a796 1d85406c
WWRRWRWR2025-11-10 13:35:16 us=281000 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, name=changeme, [email protected]
2025-11-10 13:35:16 us=281000 VERIFY KU OK
2025-11-10 13:35:16 us=281000 Validating certificate extended key usage
2025-11-10 13:35:16 us=281000 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
2025-11-10 13:35:16 us=281000 VERIFY EKU OK
2025-11-10 13:35:16 us=281000 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, name=changeme, [email protected]
WWWRRWR2025-11-10 13:35:16 us=312000 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 1024 bits RSA, signature: RSA-SHA256, peer temporary key: 253 bits X25519
2025-11-10 13:35:16 us=312000 [netgear] Peer Connection Initiated with [AF_INET]XXX.XXX.246.109:12974
2025-11-10 13:35:16 us=312000 TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1
2025-11-10 13:35:16 us=312000 TLS: tls_multi_process: initial untrusted session promoted to trusted
W2025-11-10 13:35:17 us=328000 MANAGEMENT: >STATE:1762806917,GET_CONFIG,,,,,,
2025-11-10 13:35:17 us=328000 SENT CONTROL [netgear]: 'PUSH_REQUEST' (status=1)
WRR2025-11-10 13:35:17 us=359000 PUSH: Received control message: 'PUSH_REPLY,ping 10,ping-restart 120,route-delay 10,route 192.168.1.0 255.255.255.0 192.168.1.1,route 75.2.84.193 255.255.255.255 192.168.1.1,route 99.83.191.32 255.255.255.255 192.168.1.1,peer-id 2,cipher AES-256-GCM'
2025-11-10 13:35:17 us=359000 OPTIONS IMPORT: route options modified
2025-11-10 13:35:17 us=359000 OPTIONS IMPORT: route-related options modified
2025-11-10 13:35:17 us=359000 interactive service msg_channel=936
2025-11-10 13:35:17 us=375000 ROUTE_GATEWAY 192.168.2.254/255.255.255.0 I=20 HWADDR=10:98:19:f6:54:c4
2025-11-10 13:35:17 us=375000 open_tun
2025-11-10 13:35:17 us=375000 tap-windows6 device [NETGEAR-VPN] opened
2025-11-10 13:35:17 us=375000 TAP-Windows Driver Version 9.27
2025-11-10 13:35:17 us=375000 TAP-Windows MTU=1500
2025-11-10 13:35:17 us=375000 Successful ARP Flush on interface [8] {608A8556-FD5F-4C06-8486-CA49D0B130FD}
2025-11-10 13:35:17 us=375000 do_ifconfig, ipv4=0, ipv6=0
2025-11-10 13:35:17 us=375000 MANAGEMENT: >STATE:1762806917,ASSIGN_IP,,,,,,
2025-11-10 13:35:17 us=375000 Data Channel MTU parms [ mss_fix:1367 max_frag:0 tun_mtu:1500 tun_max_mtu:1600 headroom:136 payload:1800 tailroom:568 ET:32 ]
2025-11-10 13:35:17 us=375000 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2025-11-10 13:35:17 us=375000 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2025-11-10 13:35:17 us=375000 Data Channel: cipher 'AES-256-GCM', peer-id: 2, compression: 'lzo'
2025-11-10 13:35:17 us=375000 Timers: ping 10, ping-restart 120
WrWrWRwrWRwrWrWRwrWrWrWrWrWrWrWrWRwRwRwrWrWrWRwrWRwRwRwRwrWrWrWRwrWrWRwrWrWRwRwrWrWrWRwrWrWrWRwrWrWrWRwrWrWRwrWrWRwrWRwRwrWrWRwRwrWRwRwrWRwrWrWRwRwRwrWrWRwRwrWRwRwrWrWRwRwrWrWrWrWRwRwRwRwRwRwrWrWrWRwRwrWrWrWRwrWRwrWrWRwrWrWRwRwRwRwrWrWrWRwRwRwRwRwRwRwRwrWRwRwRwRwRwRwRwRwRwRwrWrWRwRwRwrWrWrWrWRwrWrWrWrWrWRwRwrWRwrWrWRwRwRwRwrWrWrWrWRwrWrWRwRwRwRwrWrWrWrWrWRwrWrWRwRwRwRwrWrWrWrWRwrWRwRwrWrWRwRwrWrWrWrWrWRwRwRwRwrWrWrWRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwrWRwrWrWrWrWrWrWrWRwRwRwRwRwrWrWrWrWRwrWRwrWrWRwRwRwrWRwRwRwRwRwRwrWrWrWrWRwrWrWrWrWRwrWrWRwrWrWRwRwRwrWrWRwRwRwrWrWRwrWRwRwrWRwrWrWRwRwRwRwrWrWrWRwrWrWRwRwRwRwRwRwRwRwRwRwrWRwrWrWRwrWRwRwrWRwrWrWrWrWrWRwRwRwRwrWRwrWrWRwRwRwRwRwRwrWrWrWRwRwRwRwRwRwRwRwRwRwRwRwRwrWRwrWRwRwrWRwrWrWRwRwRwrWrWrWRwRwrWrWrWrWrWRwRwRwRwrWrWrWRwRwRwrWrWrWRwRwRwRwRwRwRwRwRwRwrWrWRwRwRwRwRwRwRwRwRwRwRwRwRwrWrWRwRwRwrWrWrWRwRwrWRwRwRwRwRwRwRwRwRwRwRwRwRwRwrWRwRwRwRwrWRwRwrWrWRwRwRwRwRwrWrWrWRwRwRwRwRwRwRwrWRwrWRwRwRwrWRwRwRwRwR2025-11-10 13:35:27 us=62000 TEST ROUTES: 0/0 succeeded len=-1 ret=1 a=0 u/d=up
2025-11-10 13:35:27 us=62000 WARNING: OpenVPN was configured to add an IPv4 route. However, no IPv4 has been configured for NETGEAR-VPN, therefore the route installation may fail or may not work as expected.
2025-11-10 13:35:27 us=62000 MANAGEMENT: >STATE:1762806927,ADD_ROUTES,,,,,,
2025-11-10 13:35:27 us=62000 C:\Windows\system32\route.exe ADD 192.168.1.0 MASK 255.255.255.0 192.168.1.1
2025-11-10 13:35:27 us=62000 Route addition via service succeeded
2025-11-10 13:35:27 us=62000 C:\Windows\system32\route.exe ADD 75.2.84.193 MASK 255.255.255.255 192.168.1.1
2025-11-10 13:35:27 us=62000 C:\Windows\system32\route.exe ADD 99.83.191.32 MASK 255.255.255.255 192.168.1.1
2025-11-10 13:35:27 us=78000 Route addition via service succeeded
2025-11-10 13:35:27 us=78000 Initialization Sequence Completed
2025-11-10 13:35:27 us=78000 MANAGEMENT: >STATE:1762806927,CONNECTED,SUCCESS,,XXX.XXX.246.109,12974,,
wRwrWRwRwRwRwrWRwRwRwrWRwRwRwRwrWRwrWRwRwRwrWRwRwrWRwRwRwRwRwrWrWRwRwRwRwRwRwRwRwRwrWRwRwrWrWRwRwRwrWrWrWrWrWRwrWRwRwRwRwRwRwrWrWrWrWRwRwRwrWrWrWRwRwrWRwRwRwrWRwRwRwRwRwRwRwRwRwRwRwRwrWRwrWRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwRwrWRwrWRwrWRwRwRwRwRwRwRwrWRw
