KngDa
Nov 10, 2025Aspirant
OpenVPN connects to router when clients on Ethernet but not on Wifi
I am having difficulty getting OpenVPN to work to connect to my RS300 router with my Windows 11 computers. I have a Dell XPS 16 9640 and a Microsoft Surface Pro 2103 both running Windows 11 Pro. Both...
- Dec 03, 2025
Without making any changes, the VPN connection now works over wi-fi on the Dell laptop. The only change was a firmware update from Dell including for the wi-fi adapter. I tried updating the firmware on the tablet, but the problem still persists on that computer. I will continue to look at the difference between the tunnels and see what the difference is and if I can override it.
KngDa
Log when connecting with WiFi
2025-11-10 13:28:08 WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
2025-11-10 13:28:08 us=156000 DEPRECATED OPTION: --cipher set to 'AES-128-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305). OpenVPN ignores --cipher for cipher negotiations.
2025-11-10 13:28:08 us=156000 Current Parameter Settings:
2025-11-10 13:28:08 us=156000 config = 'client.ovpn'
2025-11-10 13:28:08 us=156000 mode = 0
2025-11-10 13:28:08 us=156000 show_ciphers = DISABLED
2025-11-10 13:28:08 us=156000 show_digests = DISABLED
2025-11-10 13:28:08 us=156000 show_engines = DISABLED
2025-11-10 13:28:08 us=156000 genkey = DISABLED
2025-11-10 13:28:08 us=156000 genkey_filename = '[UNDEF]'
2025-11-10 13:28:08 us=156000 key_pass_file = '[UNDEF]'
2025-11-10 13:28:08 us=156000 show_tls_ciphers = DISABLED
2025-11-10 13:28:08 us=156000 connect_retry_max = 0
2025-11-10 13:28:08 us=156000 Connection profiles [0]:
2025-11-10 13:28:08 us=156000 proto = udp
2025-11-10 13:28:08 us=156000 local = '[UNDEF]'
2025-11-10 13:28:08 us=156000 local_port = '[UNDEF]'
2025-11-10 13:28:08 us=156000 remote = 'cameras.dyndns.org'
2025-11-10 13:28:08 us=156000 remote_port = '12974'
2025-11-10 13:28:08 us=156000 remote_float = DISABLED
2025-11-10 13:28:08 us=156000 bind_defined = DISABLED
2025-11-10 13:28:08 us=156000 bind_local = DISABLED
2025-11-10 13:28:08 us=156000 bind_ipv6_only = DISABLED
2025-11-10 13:28:08 us=156000 connect_retry_seconds = 1
2025-11-10 13:28:08 us=156000 connect_timeout = 120
2025-11-10 13:28:08 us=156000 socks_proxy_server = '[UNDEF]'
2025-11-10 13:28:08 us=156000 socks_proxy_port = '[UNDEF]'
2025-11-10 13:28:08 us=156000 tun_mtu = 1500
2025-11-10 13:28:08 us=156000 tun_mtu_defined = ENABLED
2025-11-10 13:28:08 us=156000 link_mtu = 1500
2025-11-10 13:28:08 us=156000 link_mtu_defined = DISABLED
2025-11-10 13:28:08 us=156000 tun_mtu_extra = 32
2025-11-10 13:28:08 us=156000 tun_mtu_extra_defined = ENABLED
2025-11-10 13:28:08 us=156000 tls_mtu = 1250
2025-11-10 13:28:08 us=156000 mtu_discover_type = -1
2025-11-10 13:28:08 us=156000 fragment = 0
2025-11-10 13:28:08 us=156000 mssfix = 1492
2025-11-10 13:28:08 us=156000 mssfix_encap = ENABLED
2025-11-10 13:28:08 us=156000 mssfix_fixed = DISABLED
2025-11-10 13:28:08 us=156000 explicit_exit_notification = 0
2025-11-10 13:28:08 us=156000 tls_auth_file = '[UNDEF]'
2025-11-10 13:28:08 us=156000 key_direction = not set
2025-11-10 13:28:08 us=156000 tls_crypt_file = '[UNDEF]'
2025-11-10 13:28:08 us=156000 tls_crypt_v2_file = '[UNDEF]'
2025-11-10 13:28:08 us=156000 Connection profiles END
2025-11-10 13:28:08 us=156000 remote_random = DISABLED
2025-11-10 13:28:08 us=156000 ipchange = '[UNDEF]'
2025-11-10 13:28:08 us=156000 dev = 'tap'
2025-11-10 13:28:08 us=156000 dev_type = '[UNDEF]'
2025-11-10 13:28:08 us=156000 dev_node = 'NETGEAR-VPN'
2025-11-10 13:28:08 us=156000 tuntap_options.disable_dco = ENABLED
2025-11-10 13:28:08 us=156000 lladdr = '[UNDEF]'
2025-11-10 13:28:08 us=156000 topology = 1
2025-11-10 13:28:08 us=156000 ifconfig_local = '[UNDEF]'
2025-11-10 13:28:08 us=156000 ifconfig_remote_netmask = '[UNDEF]'
2025-11-10 13:28:08 us=156000 ifconfig_noexec = DISABLED
2025-11-10 13:28:08 us=156000 ifconfig_nowarn = DISABLED
2025-11-10 13:28:08 us=156000 ifconfig_ipv6_local = '[UNDEF]'
2025-11-10 13:28:08 us=156000 ifconfig_ipv6_netbits = 0
2025-11-10 13:28:08 us=156000 ifconfig_ipv6_remote = '[UNDEF]'
2025-11-10 13:28:08 us=156000 shaper = 0
2025-11-10 13:28:08 us=156000 mtu_test = 0
2025-11-10 13:28:08 us=156000 mlock = DISABLED
2025-11-10 13:28:08 us=156000 keepalive_ping = 0
2025-11-10 13:28:08 us=156000 keepalive_timeout = 0
2025-11-10 13:28:08 us=156000 inactivity_timeout = 0
2025-11-10 13:28:08 us=156000 session_timeout = 0
2025-11-10 13:28:08 us=156000 inactivity_minimum_bytes = 0
2025-11-10 13:28:08 us=156000 ping_send_timeout = 0
2025-11-10 13:28:08 us=156000 ping_rec_timeout = 0
2025-11-10 13:28:08 us=156000 ping_rec_timeout_action = 0
2025-11-10 13:28:08 us=156000 ping_timer_remote = DISABLED
2025-11-10 13:28:08 us=156000 remap_sigusr1 = 0
2025-11-10 13:28:08 us=156000 persist_tun = ENABLED
2025-11-10 13:28:08 us=156000 persist_local_ip = DISABLED
2025-11-10 13:28:08 us=156000 persist_remote_ip = DISABLED
2025-11-10 13:28:08 us=156000 persist_key = ENABLED
2025-11-10 13:28:08 us=156000 passtos = DISABLED
2025-11-10 13:28:08 us=156000 resolve_retry_seconds = 1000000000
2025-11-10 13:28:08 us=156000 resolve_in_advance = DISABLED
2025-11-10 13:28:08 us=156000 username = '[UNDEF]'
2025-11-10 13:28:08 us=156000 groupname = '[UNDEF]'
2025-11-10 13:28:08 us=156000 chroot_dir = '[UNDEF]'
2025-11-10 13:28:08 us=156000 cd_dir = '[UNDEF]'
2025-11-10 13:28:08 us=156000 writepid = '[UNDEF]'
2025-11-10 13:28:08 us=156000 up_script = '[UNDEF]'
2025-11-10 13:28:08 us=156000 down_script = '[UNDEF]'
2025-11-10 13:28:08 us=156000 down_pre = DISABLED
2025-11-10 13:28:08 us=156000 up_restart = DISABLED
2025-11-10 13:28:08 us=156000 up_delay = DISABLED
2025-11-10 13:28:08 us=156000 daemon = DISABLED
2025-11-10 13:28:08 us=156000 log = ENABLED
2025-11-10 13:28:08 us=156000 suppress_timestamps = DISABLED
2025-11-10 13:28:08 us=156000 machine_readable_output = DISABLED
2025-11-10 13:28:08 us=156000 nice = 0
2025-11-10 13:28:08 us=156000 verbosity = 5
2025-11-10 13:28:08 us=156000 mute = 0
2025-11-10 13:28:08 us=156000 gremlin = 0
2025-11-10 13:28:08 us=156000 status_file = '[UNDEF]'
2025-11-10 13:28:08 us=156000 status_file_version = 1
2025-11-10 13:28:08 us=156000 status_file_update_freq = 60
2025-11-10 13:28:08 us=156000 occ = ENABLED
2025-11-10 13:28:08 us=156000 rcvbuf = 393216
2025-11-10 13:28:08 us=156000 sndbuf = 393216
2025-11-10 13:28:08 us=156000 sockflags = 0
2025-11-10 13:28:08 us=156000 fast_io = DISABLED
2025-11-10 13:28:08 us=156000 comp.alg = 2
2025-11-10 13:28:08 us=156000 comp.flags = 1
2025-11-10 13:28:08 us=156000 route_script = '[UNDEF]'
2025-11-10 13:28:08 us=156000 route_default_gateway = '[UNDEF]'
2025-11-10 13:28:08 us=156000 route_default_metric = 0
2025-11-10 13:28:08 us=156000 route_noexec = DISABLED
2025-11-10 13:28:08 us=156000 route_delay = 5
2025-11-10 13:28:08 us=156000 route_delay_window = 30
2025-11-10 13:28:08 us=156000 route_delay_defined = ENABLED
2025-11-10 13:28:08 us=156000 route_nopull = DISABLED
2025-11-10 13:28:08 us=156000 route_gateway_via_dhcp = DISABLED
2025-11-10 13:28:08 us=156000 allow_pull_fqdn = DISABLED
2025-11-10 13:28:08 us=156000 Pull filters:
2025-11-10 13:28:08 us=156000 ignore "route-method"
2025-11-10 13:28:08 us=156000 management_addr = '127.0.0.1'
2025-11-10 13:28:08 us=156000 management_port = '25340'
2025-11-10 13:28:08 us=156000 management_user_pass = 'stdin'
2025-11-10 13:28:08 us=156000 management_log_history_cache = 250
2025-11-10 13:28:08 us=156000 management_echo_buffer_size = 100
2025-11-10 13:28:08 us=156000 management_client_user = '[UNDEF]'
2025-11-10 13:28:08 us=156000 management_client_group = '[UNDEF]'
2025-11-10 13:28:08 us=156000 management_flags = 6
2025-11-10 13:28:08 us=156000 shared_secret_file = '[UNDEF]'
2025-11-10 13:28:08 us=156000 ciphername = 'AES-128-CBC'
2025-11-10 13:28:08 us=156000 ncp_ciphers = 'AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305'
2025-11-10 13:28:08 us=156000 authname = 'SHA1'
2025-11-10 13:28:08 us=156000 engine = DISABLED
2025-11-10 13:28:08 us=156000 replay = ENABLED
2025-11-10 13:28:08 us=156000 mute_replay_warnings = DISABLED
2025-11-10 13:28:08 us=156000 replay_window = 64
2025-11-10 13:28:08 us=156000 replay_time = 15
2025-11-10 13:28:08 us=156000 packet_id_file = '[UNDEF]'
2025-11-10 13:28:08 us=156000 test_crypto = DISABLED
2025-11-10 13:28:08 us=156000 tls_server = DISABLED
2025-11-10 13:28:08 us=156000 tls_client = ENABLED
2025-11-10 13:28:08 us=156000 ca_file = 'ca.crt'
2025-11-10 13:28:08 us=156000 ca_path = '[UNDEF]'
2025-11-10 13:28:08 us=156000 dh_file = '[UNDEF]'
2025-11-10 13:28:08 us=156000 cert_file = 'client.crt'
2025-11-10 13:28:08 us=156000 extra_certs_file = '[UNDEF]'
2025-11-10 13:28:08 us=156000 priv_key_file = 'client.key'
2025-11-10 13:28:08 us=156000 pkcs12_file = '[UNDEF]'
2025-11-10 13:28:08 us=156000 cryptoapi_cert = '[UNDEF]'
2025-11-10 13:28:08 us=156000 cipher_list = '[UNDEF]'
2025-11-10 13:28:08 us=156000 cipher_list_tls13 = '[UNDEF]'
2025-11-10 13:28:08 us=156000 tls_cert_profile = '[UNDEF]'
2025-11-10 13:28:08 us=156000 tls_verify = '[UNDEF]'
2025-11-10 13:28:08 us=156000 tls_export_peer_cert_dir = '[UNDEF]'
2025-11-10 13:28:08 us=156000 verify_x509_type = 0
2025-11-10 13:28:08 us=156000 verify_x509_name = '[UNDEF]'
2025-11-10 13:28:08 us=156000 crl_file = '[UNDEF]'
2025-11-10 13:28:08 us=156000 ns_cert_type = 0
2025-11-10 13:28:08 us=156000 remote_cert_ku[i] = 65535
2025-11-10 13:28:08 us=156000 remote_cert_ku[i] = 0
