Aarav's avatar
Aarav
Follower
Apr 10, 2025
Overheating Issues with Nighthawk RS200 Router
I'm using the Nighthawk RS200 (WiFi 7) and noticed it gets quite warm after a few hours specially when I do multitasking like TaskFlix, even in a well-ventilated room. No performance issues yet, but the heat is concerning.
Firmware: 1.0.0.34
Environment: 20+ connected devices, room temp ~22°C
Has anyone else faced similar heating issues? Is this normal for this model or should I be worried?
Thanks in advance!
1 Reply
  • plemans's avatar
    they will generate some heat. Got a temp gun? How hot is it actually?
