CoppiceBoy
Oct 26, 2024Aspirant
Port Forwarding on Nighthawk RS500 & Starlink
I've recently switched to Starlink which has dramatically increased the Internet speeds in our rural location. I have the Starlink router on 'bypass' and connected to a Nighthawk RS500 WiFi router. E...
Oct 28, 2024Guru - Experienced User
If the RS is indicating a 145.x IP address then this would be what the RS is getting from the ISP thru the startlink modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is uPnP disabled on the RS router prior to setting up a PF configuration?
CoppiceBoy
Oct 28, 2024Aspirant
Thanks FURRYe38,
On further investigation, it appears that Starlink works on CGNAT so nothing is going to get through to the NG router! I'm now learning all about OpenVPN and hope to set up a VPN tunnel to bypass the Starlink router.
- FURRYe38Oct 28, 2024Guru - Experienced User
Check to see if the SL Router has a DMZ feature, if it does, try inputting the IP address given by the SL router to the RS in the SL router DMZ.
- CoppiceBoyOct 29, 2024Aspirant
No, the Starlink router does not support DMZ ....
Thanks anyway.
- FURRYe38Oct 29, 2024Guru - Experienced User
I know from what others posted about SL, they were able to get some kind of SL modem to ethernet adapter and then install a 1Gb non managed switch in between this adapter and the connecting downstream router. Not sure of you have this adapter from SL or something different. Sounds like this maybe an ISP issue that you should contact them and get there help with there configurations.
