ALNiKO
Sep 28, 2023Aspirant
Port Forwarding on RS700
Hi all! I received my RS700 several days ago and I'm pretty happy with Wi-Fi speeds, coverage and setup. However, I'm struggling to get port forwarding to work. I have Pace 5268AC modem/router fr...
- Oct 03, 2023
Hi ALNiKO,
Thank you for working with us offline. As you have confirmed the tiral firmware has fixed the issue, and we will include the fix in a maintenance release, which we expect to happen later this year.
BH_C
Sep 29, 2023NETGEAR Expert
Hi ALNiKO,
I would like to make sure I understand your issue correclty, is this description correct?
* When the Port Forwarding rule is disabled
- local computer 10.0.0.10 can access http://10.0.0.20:7809 and http://<external IP>:7089 (or https?)
- local computer 10.0.0.10 cannot access http://10.0.0.20:7809 or http://<external IP>:7089.
- But the lcoal computer 10.0.0.10 can access
> telnet 10.0.0.10 7089
> telnet <external IP> 7089
- And an external computer can access http://<external IP>:7089.
Thanks.
- ALNiKOSep 29, 2023Aspirant
Hi!
* When the Port Forwarding rule is enabled
This is correct.
- BH_COct 03, 2023NETGEAR Expert
Hi ALNiKO,
- jonathan16833Oct 06, 2023Guide
I was just losing my mind trying to figure out what was wrong with my server, what a huge oversight. Can I get the new firmware as well?
Thank you,
- WestSiderNov 03, 2023Aspirant
Hello,
I have a similar issue that is happening with a NVR server for local use as well as a security team for after business hours that would monitor remotely. The firmware addressed the port forwarding issue but now when the remote users access the Live video feed it is very choppy, losses connection, or buffers continuously. After the firmware was installed I did a factory reset and reconfigured as well, any tips for this?
I also have tried other Netgear Wi-Fi routers with no issues on that hardware.
Thanks,
