ALNiKO
Sep 29, 2023Aspirant
Port Forwarding on RS700
Hi all! I received my RS700 several days ago and I'm pretty happy with Wi-Fi speeds, coverage and setup. However, I'm struggling to get port forwarding to work. I have Pace 5268AC modem/router fr...
- Oct 03, 2023
Hi ALNiKO,
Thank you for working with us offline. As you have confirmed the tiral firmware has fixed the issue, and we will include the fix in a maintenance release, which we expect to happen later this year.
ALNiKO
Hi!
* When the Port Forwarding rule is disabled
- local computer 10.0.0.10 can access http://10.0.0.20:7809
* When the Port Forwarding rule is enabled
- local computer 10.0.0.10 cannot access http://10.0.0.20:7809 or http://<external IP>:7089.
- But the lcoal computer 10.0.0.10 can access
> telnet 10.0.0.10 7089
> telnet <external IP> 7089
- And an external computer can access http://<external IP>:7089.
This is correct.
BH_C
Oct 03, 2023NETGEAR Expert
Hi ALNiKO,
- jonathan16833Oct 06, 2023Guide
I was just losing my mind trying to figure out what was wrong with my server, what a huge oversight. Can I get the new firmware as well?
Thank you,
- BH_COct 06, 2023NETGEAR Expert
Sorry about the trouble, we will pass you the trial firmware offline. Thanks.
- jonathan16833Oct 07, 2023Guide
The link you provided in the DM did not work, someone called me from netgear and sent me a new link to RS700-V1.0.7.68_2.0.74 this firmware solved the issue.
