jprobins007
May 25, 2024Tutor
Possible to Setup Failover with RS700
Is it possible to set up an automatic Internet failover (LTE or cable) for the RS700? I understand this would require an adapter or additional device since the RS700 is, itself, not dual or multi WAN...
May 25, 2024Guru - Experienced User
Natively, no, the RS doesn't have failover features. Would need external equipment for this.
jprobins007 wrote:
Is it possible to set up an automatic Internet failover (LTE or cable) for the RS700? I understand this would require an adapter or additional device since the RS700 is, itself, not dual or multi WAN. Presuming the answer is "yes", what are the options? Would it be possible to use a product similar to the UniFi LTE Backup Pro?
jprobins007
May 25, 2024Tutor
Furry, are you saying that ShadowMario's suggestion above will not work? Or are you just confirming that the RS700 is not dual WAN?
- FURRYe38May 25, 2024Guru - Experienced User
RS only has LAG, not dual WAN for fail over internally.
I presume how he has it working with external HW, is working for him.
- ShadowMario3May 25, 2024Luminary
Yeah, Furry was just mentioning that the RS700 doesn't have failover internally. You need a second router that has failover capabilities, connect the RS700's WAN to the router's LAN, then you should be good to go. The second router will handle the failover and there shouldn't be any downtime on the RS700.
- jprobins007May 26, 2024TutorThank you both very much. That is a great help.
- TopologyMay 27, 2024Virtuoso
jprobins007, you may wish to consider the following equipment for adding WAN failover to a router: NETGEAR LM1200; Cradlepoint L950 or W1850.
