jprobins007
May 25, 2024Tutor
Possible to Setup Failover with RS700
Is it possible to set up an automatic Internet failover (LTE or cable) for the RS700? I understand this would require an adapter or additional device since the RS700 is, itself, not dual or multi WAN...
jprobins007
May 25, 2024Tutor
Furry, are you saying that ShadowMario's suggestion above will not work? Or are you just confirming that the RS700 is not dual WAN?
May 25, 2024Guru - Experienced User
RS only has LAG, not dual WAN for fail over internally.
I presume how he has it working with external HW, is working for him.
