Caden_Cotard
Feb 13, 2024Aspirant
Preamble Puncturing feature in RS700- Nighthawk Triband WIFI 7 AP
Hi I have been using this Netgear access point for a while BE19000 WiFi Router (RS700S) Nighthawk Tri-Band WiFi 7 Router, 19Gbps, 10 Gig Ports with 1-year NETGEAR Armor™. I want to check the prea...
BH_C
Feb 14, 2024NETGEAR Expert
Hi,
RS700 currently does not support the preamble puncturing (Multi-RU) function. We've been working on it and aim to release the firmware soon, but I cannot share the schedule. If you are interested in testing some trial builds, I can arrange to send you internal releases. Thanks.
- BH_CFeb 14, 2024NETGEAR Expert
Sorry, I have to correct my response. Regarding the preamble puncturing (Multi-RU) function, we are not certain if we will support it on RS700.
- Caden_CotardFeb 14, 2024Aspirant
Thanks for the quick update regarding that. Are there any Netgear WiFi7 AP models that supports preamble puncturing feature and i have WAX-630 Nergear 6GHz access point will that support the puncturing in AX level?
- BH_CFeb 15, 2024NETGEAR Expert
The preamble puncturing feature is a WiFi 7 function, it is not supported on WiFi 6 or WiFi 6E.
May I know your use case for the preamble puncturing? how do you want to use it on a router or AP? Thanks.
