Taz40
Jan 10, 2024Aspirant
Problem using HTTP / HTTPS Readyshare
Good morning, I currently have a problem with my RS700 router (Firmware: 1.0.7.82_2.0.80) I use readyshare to be able to download my files from the internet to my usb key connected to the router bu...
Jan 10, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Does this happen in other browsers as well?
BH_C
Jan 10, 2024NETGEAR Expert
I believe our Readyshare does not support upload/write through HTTP/HTTPS. You can only upload files to the attached USB storage device through FTP or SMB.
- Taz40Jan 10, 2024Aspirant
Yes, that's what I'm trying to do.
I forgot to specify that I only had this problem with files larger than 1.5GB
