thisiskav
Sep 25, 2025Aspirant
Protection Engine and Stealth ports
Hello, Recently, I purchased a Nighthawk RS100 Router. After configuring it, I tested my setup using Shields Up . All my ports reported as Stealth and the router log was clean of anything seriou...
Sep 26, 2025Guru - Experienced User
You'll need to either keep PE disabled if you want all stealth ports to be seen otherwise leave it as is. Something we've already passed on to NG for review. No idea IF or when they will make adjustments. All up to them. Nothing else we can do.
