thisiskav
Sep 25, 2025Aspirant
Protection Engine and Stealth ports
Hello, Recently, I purchased a Nighthawk RS100 Router. After configuring it, I tested my setup using Shields Up . All my ports reported as Stealth and the router log was clean of anything seriou...
thisiskav
Sep 26, 2025Aspirant
Thank you kindly for your replies!
I agree with you, CrmipOn, Stealth is the way to go!
My plan is to disable to PE for the time being and repeat the test after each release of the router firmware.
