CKopp
Sep 14, 2024Apprentice
R7960P vs. RS280S range
I am looking to update my old router - R7960P in hopes of finally resolving the DNS problem introduced by the last security update (DNS time outs that were only fixable by setting DNS per each device...
Sep 17, 2024Guru - Experienced User
IF you want to use Armor. Up to you. The RS will come with a free trial of Armor.
CKopp
Sep 17, 2024Apprentice
My question really concerns thew implentation of Armor. To clarify, my assumption is that if I want to use it I only need it on the actual router, not on the Router and the AP.
- FURRYe38Sep 18, 2024Guru - Experienced User
Correct. AP mode, most features are disabled so would be of no use in that mode.
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
