NERaptorRunner
Oct 16, 2024Star
Re: 5ghz Randomly Disappears
I have the very same issue. 5Ghz goes away until reboot. Most I have made it without reboot is 15 days. When it is up, the range and speed is good. I had the RAX 200 with EX8000 extender. I have ...
Oct 16, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many devices are connected to the router?
Brand and model#s of devices you have connected?
Is Smart Connect enabled or disabled?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Protection Engine, Traffic Meter.
