NERaptorRunner
Oct 16, 2024Star
Re: 5ghz Randomly Disappears
I have the very same issue. 5Ghz goes away until reboot. Most I have made it without reboot is 15 days. When it is up, the range and speed is good. I had the RAX 200 with EX8000 extender. I have ...
BH_C
Oct 17, 2024NETGEAR Expert
Hi NERaptorRunner,
Can you try the 5GHz set to channel 40 and mode "Up to 2.9 Gbps" to see if the connection becomes stable?
Thanks.
- NERaptorRunnerOct 17, 2024Star
I will try that. Thanks.
- FURRYe38Oct 21, 2024Guru - Experienced User
- NERaptorRunnerOct 24, 2024StarHad to reboot after 2 days. Set back to auto. Up for 3 days now. Hard to troubleshoot. Sometimes it will go a few weeks.
