NERaptorRunner
Oct 16, 2024Star
Re: 5ghz Randomly Disappears
I have the very same issue. 5Ghz goes away until reboot. Most I have made it without reboot is 15 days. When it is up, the range and speed is good. I had the RAX 200 with EX8000 extender. I have ...
BH_C
Oct 17, 2024NETGEAR Expert
Hi NERaptorRunner,
Can you try the 5GHz set to channel 40 and mode "Up to 2.9 Gbps" to see if the connection becomes stable?
Thanks.
NERaptorRunner
Oct 17, 2024Star
I will try that. Thanks.
- FURRYe38Oct 21, 2024Guru - Experienced User
- NERaptorRunnerOct 24, 2024StarHad to reboot after 2 days. Set back to auto. Up for 3 days now. Hard to troubleshoot. Sometimes it will go a few weeks.
- FURRYe38Oct 24, 2024Guru - Experienced User
