NERaptorRunner
Oct 16, 2024Star
Re: 5ghz Randomly Disappears
I have the very same issue. 5Ghz goes away until reboot. Most I have made it without reboot is 15 days. When it is up, the range and speed is good. I had the RAX 200 with EX8000 extender. I have ...
NERaptorRunner
Oct 17, 2024Star
I will try that. Thanks.
Oct 21, 2024Guru - Experienced User
- NERaptorRunnerOct 24, 2024StarHad to reboot after 2 days. Set back to auto. Up for 3 days now. Hard to troubleshoot. Sometimes it will go a few weeks.
- FURRYe38Oct 24, 2024Guru - Experienced User
Can you try the 5GHz set to channel 40 and mode "Up to 2.9 Gbps" to see if the connection becomes stable?
I downloaded WIFI analyzer tool and ran on laptop in same area where devices are not seeing 5GHz channel when things go afoul. Very noisy around channel 40. I set to channel 100. We will see. Thanks to all for advice.
