NERaptorRunner
Oct 16, 2024Star
Re: 5ghz Randomly Disappears
I have the very same issue. 5Ghz goes away until reboot. Most I have made it without reboot is 15 days. When it is up, the range and speed is good. I had the RAX 200 with EX8000 extender. I have ...
NERaptorRunner
Jul 19, 2025Star
The router is on 40(p).The Satellite is on 157(p). Devices are connecting to Satellite without issue.
Jul 20, 2025Guru - Experienced User
IF the RBR is on 40, then the RBS should also be on channel 40 for 5Ghz.
Channel 157 should be for wireless backhaul.
Can you post a screen capture of the RBS web page UI?
NERaptorRunner wrote:The router is on 40(p).The Satellite is on 157(p). Devices are connecting to Satellite without issue.
