Pencanto
May 04, 2024Aspirant
Change from nighthawk AX8 AX6600 to nighthawk RS700S WiFi 7
What do I have to do if I want to replace my nighthawk AX8 to a the new WIFI 7. Do I need to contact netgear about the change? This will go to my account and it’s just like a plug and play? Disconnect...
Pencanto
I don’t understand check if I have clients that work with WIFI 7. This is for my home and to get better and faster WiFi speeds. For my Apple TV, Xbox, etc. thank you!
microchip8
May 04, 2024Master
AppleTV nor Xbox support WiFi7. At most, they can do WiFi6 or 5. You cannot magically get "better and faster speeds" if the underlying hardware does not support it just by upgrading the router.
- PencantoMay 04, 2024AspirantThat’s a very helpful information!! Thank you! I’m not tech savvy as you can see. You just saved me $700 bucks!! Thx!!
