Ru123
Jan 08, 2025Aspirant
Disappearing SSID nighthawk be9300
I’m hoping someone here can help; every time I power cycle my router the SSID completely disappears and I can’t find it on any of our devices. Before turning off and on again everything is fine and co...
- Jan 09, 2025
After looking through the community some more I think this might be what’s happening; my isp requires vlan group tagging. I also tested and it doesn’t happen until i change that setting.
https://community.netgear.com/t5/Nighthawk-with-WiFi-7-BE/RS280-Rebooting-kills-wifi-radios-when-VLAN-tag-group-is-enabled/m-p/2399684/highlight/false#M1537Hi Ru123, Thanks for the info. I've sent you a PM with the link for the tiral firmware that fixes this issue.
Ru123
Jan 09, 2025Aspirant
Firmware is V1.0.1.60
We have fttp so the router is plugged in to the nbn box with a cat6 cable.
Its RS300
What is an RMA?
Its RS300
What is an RMA?
BH_C
Jan 09, 2025NETGEAR Expert
- Ru123Jan 10, 2025AspirantThank you! That’s done it! Now to try and get UPnP to work with our Xbox’s.
