tvarsano
Dec 28, 2023Initiate
MLO (Multi Link Operation) WiFi7 of RS700
Hi, Does RS700 with V1.0.7.82_2.0.80 support MLO (Multi Link Operation) WiFi7 capability? How should I configure it?
DarrenM
Dec 03, 2024Sr. NETGEAR Moderator
Multi-Link Operation (MLO) is an advanced WiFi 7 feature that allows your devices to use multiple WiFi bands simultaneously, providing improved performance and reliability. To take advantage of MLO, both your WiFi 7 router and compatible devices must support this feature.
We’re actively working on a firmware update to enable MLO on the RS700 router. As soon as the update is ready, we will share all the details here. We sincerely appreciate your patience as we strive to enhance your WiFi experience.
Thank you for being a NETGEAR customer.
DarrenM
