Camaxtli1207
Jan 19, 2025Apprentice
Re: Netgear Nighthawk RS300
My Nighthawk RS300 router has been acting ever since the firmware updated to v1.0.1.60, in 2024 wifi and internet gave me no problems, but ever since 2025 started my wifi just randomly disconnects and...
Jan 19, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What wireless channels are set on the RS web page?
Is Protection Engine enabled on the RS routers web page? Under Advanced Tab/Administration/Security. If so, disable this feature, apply the change and reboot the router.
Camaxtli1207
Jan 22, 2025Apprentice
Idk what Mfr is sorry but the modem is from Spectrum 400mbs is internet speed, modem is model EU2251
I have CAT7 Cables, wireless channels 2GHz is channel 1, 5GHz is 64 I think and 6GHz is 37. The protection engine is disabled and the netgear armor is disabled and I also disabled some called UMC something i cant remember right now what it was called if was in the security settings. My wifi sometimes just cuts off i could be watching netflix or gaming and it will randomly lag. I will try reverting back to the old firmware. Because before the update everything was fine.
- FURRYe38Jan 23, 2025Guru - Experienced User
Try channel 11 on 2.4, channel 50 on 5Ghz
Try enabling Protection Engine and make sure it updates to what is seen here while latest FW version is loaded:
Mfr = Manufacturer.
The EU2251 is a Hitron branded/Mfr model I believe.
- Camaxtli1207Jan 23, 2025ApprenticeMy routers 5GHz doesnt have a channel 50 only 36,40,44,48 then goes to 52(dfs)i attached a screen shot, also i remembered what i disabled its called, MU-MIMO. Someone told that disabling this would help with the internet connecting issue it worked for a bit but it went back to lagging again after a few days. Also i live in LA so i donât know if the fires also have something to do with my connection. hope you al can help me with this issue đ
Oops, Typo on my part. Sorry about that, ya, meant to say channel 40.
I would keep MIMO enabled.
Not sure if that event would impact issues. Hope your ok otherwise. đ
- BH_CJan 24, 2025NETGEAR Expert
In addition to setting to channel 40 for the 5GHz, please also change the mode to "Up to 1.4Gbps" to avoid radar interference to see if that helps.
- Camaxtli1207Jan 25, 2025ApprenticeOkay i will try doing this too i will return in a week to test it out, with the previous setting it seemed to still randomly lag, I will try setting my 5GHz down to 1.4 and also my 2GHz to .4
