Camaxtli1207
Jan 19, 2025Apprentice
Re: Netgear Nighthawk RS300
My Nighthawk RS300 router has been acting ever since the firmware updated to v1.0.1.60, in 2024 wifi and internet gave me no problems, but ever since 2025 started my wifi just randomly disconnects and...
Jan 23, 2025Guru - Experienced User
Try channel 11 on 2.4, channel 50 on 5Ghz
Try enabling Protection Engine and make sure it updates to what is seen here while latest FW version is loaded:
Mfr = Manufacturer.
The EU2251 is a Hitron branded/Mfr model I believe.
Camaxtli1207
Jan 23, 2025Apprentice
My routers 5GHz doesnt have a channel 50 only 36,40,44,48 then goes to 52(dfs)i attached a screen shot, also i remembered what i disabled its called, MU-MIMO. Someone told that disabling this would help with the internet connecting issue it worked for a bit but it went back to lagging again after a few days. Also i live in LA so i donât know if the fires also have something to do with my connection. hope you al can help me with this issue đ
- FURRYe38Jan 23, 2025Guru - Experienced User
Oops, Typo on my part. Sorry about that, ya, meant to say channel 40.
I would keep MIMO enabled.
Not sure if that event would impact issues. Hope your ok otherwise. đ
- Camaxtli1207Jan 23, 2025ApprenticeOkay Iâll try those settings ^_^ iâll let then run for a week and come back with an update.
