Camaxtli1207
Jan 19, 2025Apprentice
Re: Netgear Nighthawk RS300
My Nighthawk RS300 router has been acting ever since the firmware updated to v1.0.1.60, in 2024 wifi and internet gave me no problems, but ever since 2025 started my wifi just randomly disconnects and...
BH_C
Jan 24, 2025NETGEAR Expert
In addition to setting to channel 40 for the 5GHz, please also change the mode to "Up to 1.4Gbps" to avoid radar interference to see if that helps.
Camaxtli1207
Jan 25, 2025Apprentice
I updated the setting you suggested, but I still keep having issues, I hope NG comes up with another update soon to fix this one, because I am now thinking of going back to my old Nighthawk (AC1900) router that one gave no issues at all and was easier to set up than this RS300; I spent $300+ on the RS300, now I am kinda regretting upgrading. The AC1900 never gave me issues I think I had it for 10+ years and it gave me flawless connections, so far the RS300 is falling short after only having it for a couple months.
- BH_CJan 27, 2025NETGEAR Expert
Hi Camaxtli1207,
* When disconnection happened, could the device reach the router? e.g. accessing the routrer's web GUI?
* did you use same SSID for all the 3 bandss (2.4GHz, 5GHz, 6GHz)? can you try different SSID for different band and to connect all your devices to the 5GHz only (using ch 40 and "up to 1.4Gbps" mode)?
- kermitConsultJan 27, 2025Tutor
Yes the router was responding.
Yes, all I changed was the channels for the 3 bands
- Camaxtli1207Jan 28, 2025Apprentice* When disconnection happened, could the device reach the router? e.g. accessing the routrer's web GUI? YES
* did you use same SSID for all the 3 bandss (2.4GHz, 5GHz, 6GHz)? can you try different SSID for different band and to connect all your devices to the 5GHz only (using ch 40 and "up to 1.4Gbps" mode)? YES- BH_CJan 28, 2025NETGEAR Expert
In the case where devices cannot access the internet but can access the router's Web GUI:
* check the Internet LED on the front panel, is it white, amber, or off?
* If the LED is not off, go to the Connect Status window from the Web GUI (a button on the Internet Port tile on the Advanced tab / Dashboard), check if there is IP address assigned? perform Release / Renew or Disconnect / Connect to see if the connect gets restored.
