Camaxtli1207
Jan 19, 2025Apprentice
Re: Netgear Nighthawk RS300
My Nighthawk RS300 router has been acting ever since the firmware updated to v1.0.1.60, in 2024 wifi and internet gave me no problems, but ever since 2025 started my wifi just randomly disconnects and...
Camaxtli1207
Jan 28, 2025Apprentice
* When disconnection happened, could the device reach the router? e.g. accessing the routrer's web GUI? YES
* did you use same SSID for all the 3 bandss (2.4GHz, 5GHz, 6GHz)? can you try different SSID for different band and to connect all your devices to the 5GHz only (using ch 40 and "up to 1.4Gbps" mode)? YES
BH_C
Jan 29, 2025NETGEAR Expert
In the case where devices cannot access the internet but can access the router's Web GUI:
* check the Internet LED on the front panel, is it white, amber, or off?
* If the LED is not off, go to the Connect Status window from the Web GUI (a button on the Internet Port tile on the Advanced tab / Dashboard), check if there is IP address assigned? perform Release / Renew or Disconnect / Connect to see if the connect gets restored.
- Camaxtli1207Jan 29, 2025Apprentice* check the Internet LED on the front panel, is it white, amber, or off? White
* If the LED is not off, go to the Connect Status window from the Web GUI (a button on the Internet Port tile on the Advanced tab / Dashboard), check if there is IP address assigned? There is an IP assigned.
I have done this and it connects successfully, but some 20 mins or so it disconnects again. I think the longest it has gone so far without issues is about a night and then it starts having issues again. - Camaxtli1207Jan 30, 2025ApprenticeLooks like NG dropped the ball with the new updates, slowing down all routers n now they’re having problems. My rs300 is having connection issues and nothing i do is fixing it I’m going to go back to a AC1900 at this point that night hawk router never gave me issues in 10 years. This new wifi 7 rs300 is already having problems after only 4 months, I’m disappointed NG.
- Camaxtli1207Jan 31, 2025ApprenticeThe light is on white but blinking and i see on the app i dont know what it means, the renew fixed the problem for a couple hours then it had disconnection issues again.
- Camaxtli1207Mar 24, 2025ApprenticeYes I have just waiting for a reply hopefully they give me a RMA code, because I have only had this router for 4 months and its acting up this badly, it was working fine for the first two months then all of a sudden starting acting up in Feb. Before the RS300 I had an older model of the nighthawk AC1900 and that one lasted 9 years before it started acting up. I hope i get the RMA ^_^
