JohnNadeau
Dec 29, 2024Apprentice
Re: RS700 assigning same IP address to more than one device.
Hi BH_C Getting ready to try the Trial Firmware you sent me for the Rs700, thank you! Do you know if the Rs700/BE19000 suffered from the same issue as the RS280S/BE9200 in the BPDU being sen...
- Dec 29, 2024
RS700 does not have the BPDU issue. This is trial firmware, we don't have release notes for it.
BH_C
Dec 29, 2024NETGEAR Expert
