Ricgonzalez14
Apr 13, 2026Aspirant
RS140 Previously configured device does not connect to the Wi-Fi network.
Hi, I have my company laptop and it ran out of battery while connected to my company's VPN. It also uses Cisco Anny Connect. After recharging, it won't connect to the Wi-Fi network with my RS140 rout...
Apr 14, 2026Guru - Experienced User
Might even check with the work IT department to see if there's any known issues with that happening.
If you hardwire in the laptop, will it connect?
- StephenBApr 14, 2026Guru - Experienced User
Might also be worth creating a guest network, and see if it connects to that.
