Timlab55's avatar
Apr 19, 2025
RS200
Just replacing my ASUS GS-AX5400 router with the Netgear RS200.  Need some insight on the setup before it get's here.  I have an AT&T BGW Router that is connected to my fibre opt cable.  Now the GS-A...
  • michaelkenward's avatar
    Apr 19, 2025
    What is that? (That label could be one of many things.)
    How is it configured?
    If it is running as a router, then you run the risk  of conflicts.
    Two routers on your network can cause headaches. For example, you can end up with local problems with addresses on your network. Among other things, the other router can misdirect traffic to addresses that the Netgear router usually handles, such as routerlogin.net or the usual default IP address for a router, 192.168.1.1.
    This explains some of the other drawbacks.
    What is Double NAT? | Answer | NETGEAR Support
    Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point (AP) with a wired connection to the main router. Netgear advises this, as does just about every site you will visit.
    How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
    But that has its own drawbacks:
    Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
    It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.
    The reason is that the GS-AX5400 will only support 24 devices connected to it.  I'm beling (from what I've read) is that the RS200 can support 80.connected devices.
    Have you actually experienced issues with this? Or is it just something you read somewhere?
    Just another user with time on their hands.
