Araz
Mar 28, 2025Aspirant
Re: RS300 random disconnect from the internet
I have similar issue with this new RS 300 Wifi7 router. Paid amoist 400 dollars for it, but doesn't work properly. I lose internet constantly, maybe every 4-6 minutes. Sometimes it wokrs longer, but ...
Apr 01, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Armor, IPv6, Smart Parental Controls or Circle, Protection Engine, Traffic Meter.
Araz
Apr 05, 2025Aspirant
Its the latest firmware 1.0.1.74
I dont know what is Mfr, please let me know
Service Provider is Telus Fiber Optic, There is a Modem that my Wifi Router is connected to
Yes, i am using good CAT 6 cable.
Armor is diabled
Smart Control is on
Parental Control is disabled
Traffic Meter is enabled
I dont have protection Engine.
Thanks for trying to help!
- FURRYe38Apr 06, 2025Guru - Experienced User
What is the brand and model# of the ISP modem?
Does the RS Internet LED turn AMBER when this happens?
