coolwifi
Jun 13, 2026Virtuoso
RS500 Firmware Version 1.2.7.2 released
Get it here https://support.netgear.com/support/product/rs500 Release notes : https://kb.netgear.com/000070819/
coolwifi
Jun 14, 2026Virtuoso
No, whatever entries are set in the 3 DNS settings, cloudflare DNS gets passed on to the client devices. You could use browserleaks DNS leak test in the Web to test the DNS servers that a client device is using, I see cloudflare DNS in that list along with my ISP DNS servers.
CrimpOn
Jun 14, 2026Guru - Experienced User
(I LOVE the Community Forum because every day there are "new things" that I knew nothing about....)
My PC Ethernet adapter clearly shows one DNS entry: 192.168.1.1 (the Netgear Orbi router)
The router is set to use Cloudflare (1.1.1.1) and Google (8.8.8.8, 8.8.4.4)
How does this DNS Leak Test claim that my web browser is resolving DNS using a bunch of different IP addresses?????
- coolwifiJun 14, 2026Virtuoso
The edge DNS servers (8.8.8.8 or 1.1.1.1) passed on by the router DHCP get resolved to the actual DNS servers geographically closer to your IP location. Those DNS servers are revealed by the browserleaks tool.
- CrimpOnJun 14, 2026Guru - Experienced User
This "makes no sense" to me, which is good in a way (because I LOVE learning new things).
My router does not "pass on" any DNS information to individual devices. It says, "for DNS, send queries to 192.168.1.1")
When I enable LAN/WAN capture on the router, the WAN capture shows DNS queries and responses from the router (public IP) to 1.1.1.1 and 8.8.8.8 but does not record anything else.
(It is late, and I am losing focus, so.....) I will attempt this again tomorrow.
So far, this Browser Leaks took remains a mystery.
- coolwifiJun 15, 2026Virtuoso
8.8.8.8 is the IP address of the edge DNS server closest to your location. The actual DNS servers sending the DNS responses might be in a different physical location. For example in my case 8.8.8.8 is in Seattle, but the actual Google DNS servers are in Oregon. The browserleaks tool shows the IP addresses of the actual physical DNS servers being used for DNS resolution by the browser.
