Karllen
Jan 11, 2025Follower
Re: RS600 Internet dropping out consistently
Having the same or similar issue with devices connecting to WiFi 7 and in mid use dropping connection to WiFi and going to mobile data.
Other devices that are not WiFi 7 are now no longer able to see the 2.4 or 5 WiFi .
I have been using the Netgear Smart Connect okay for about a month then with no changes to the router it stopped working one day.
I am running latest firmware, have armour subscription.
Never had a problem with my Mikrotiks or Fortigates so finding this product to be disappointing so far.
1 Reply
What channels are you using?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageIs Protection Enging enabled on the RS router? If so, disable this.
