kermitConsult
Jan 15, 2025Tutor
Re: RS600 Internet dropping out consistently
I am too suffering from this issue. Support desk did not have a solution. I am throwing the router in the bin. Brian Green [email protected]
- Jan 16, 2025
OK Changed the channels as requested, set the Primary DNS to 9.9.9.9
I will let you know how it goes.
Jan 15, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is Protection Engine enabled on the RS routers web page? Under Advanced Tab/Administration/Security. If so, disable this feature, apply the change and reboot the router.
- kermitConsultJan 15, 2025Tutor
- Firmware: v1.0.1.60
- NTU: Huawei P125F
- Cable: Cat6E
- Protection Engine: OFF
- FURRYe38Jan 15, 2025Guru - Experienced User
- NTU: Huawei P125F Doesn't pull up as being a valid model# or brand for that model #. Is that the ISP modem or ONT? Be sure to verify the ISP Modem and model # using the sticker on the unit.
Has PE been disabled all this time? Or just disabled it?
Does the Front INTERNET LED turn AMBER when this happens?
Sorry wrong label
Huawei EchoLife HG8242H GPON Terminal
