kermitConsult
Jan 15, 2025Tutor
Re: RS600 Internet dropping out consistently
I am too suffering from this issue. Support desk did not have a solution. I am throwing the router in the bin. Brian Green [email protected]
- Jan 16, 2025
OK Changed the channels as requested, set the Primary DNS to 9.9.9.9
I will let you know how it goes.
kermitConsult
Jan 15, 2025Tutor
- Firmware: v1.0.1.60
- NTU: Huawei P125F
- Cable: Cat6E
- Protection Engine: OFF
Jan 15, 2025Guru - Experienced User
- NTU: Huawei P125F Doesn't pull up as being a valid model# or brand for that model #. Is that the ISP modem or ONT? Be sure to verify the ISP Modem and model # using the sticker on the unit.
Has PE been disabled all this time? Or just disabled it?
Does the Front INTERNET LED turn AMBER when this happens?
- kermitConsultJan 15, 2025Tutor
Sorry wrong label
Huawei EchoLife HG8242H GPON Terminal
PE was turned off on day 2. (Now about day 58)
LED Light is green.
And I can run a speed test via the NightHawk app successfully, (DL 938 UP 58) while all other devices are not able to connect.
- FURRYe38Jan 15, 2025Guru - Experienced User
Well I don't see a fully on router at the ONT, however it may have some routing abilities. There is a DMZ feature on this model I believe. Something you might ask the ISP about using for the RS router.
Powering OFF the RS router then back ON brings the rest of the devices into working and getting internet services?
What channels are you using on the RS?
Is Smart Connect enabled or disabled?
Is IPv6 enabled or disabled?
Are you using auto detected ISP DNS or custom DNS? Might give cloudfare or quad 9 DNS a try for IPv4.
YES, internet connection is up and running
2.4, 5 & 6
Currently enabled. Have tried both option no difference still drops internet connection
Is IPv6 enabled or disabled? DISABLED
Auto-detect
202.142.142.142
202.142.142.242
