kermitConsult
Jan 15, 2025Tutor
Re: RS600 Internet dropping out consistently
I am too suffering from this issue. Support desk did not have a solution. I am throwing the router in the bin. Brian Green kermit.consulting@gmail.com
- Jan 16, 2025
OK Changed the channels as requested, set the Primary DNS to 9.9.9.9
I will let you know how it goes.
Jan 16, 2025Guru - Experienced User
kermitConsult wrote:
Powering OFF the RS router then back ON brings the rest of the devices into working and getting internet services?
YES, internet connection is up and running
What channels are you using on the RS?
2.4, 5 & 6
These are frequencies, not channels.
Is Smart Connect enabled or disabled?
Currently enabled. Have tried both option no difference still drops internet connection
Is IPv6 enabled or disabled? DISABLED
Are you using auto detected ISP DNS or custom DNS? Might give cloudfare or quad 9 DNS a try for IPv4.
Auto-detect
202.142.142.142
202.142.142.242
And Protection Engine is disabled currently?
kermitConsult
Jan 16, 2025Tutor
2.4, 5 & 6
They are set to Auto, so not sure which ones are being used.
Auto-detect
202.142.142.142
202.142.142.242
Have changed the DNS to Manual and set it to 9.9.9.9
And Protection Engine is disabled currently? Yes
- FURRYe38Jan 16, 2025Guru - Experienced User
Might set channels to 1, 40 and 69 for each of those frequencies.
Let us know if changing to a different DNS helps.
- kermitConsultJan 16, 2025Tutor
- kermitConsultJan 26, 2025Tutor
The changes to the channels did the trick
