kermitConsult
Jan 15, 2025Tutor
Re: RS600 Internet dropping out consistently
I am too suffering from this issue. Support desk did not have a solution. I am throwing the router in the bin. Brian Green kermit.consulting@gmail.com
- Jan 16, 2025
OK Changed the channels as requested, set the Primary DNS to 9.9.9.9
I will let you know how it goes.
kermitConsult
Jan 16, 2025Tutor
What channels are you using on the RS?
2.4, 5 & 6
These are frequencies, not channels.
They are set to Auto, so not sure which ones are being used.
Are you using auto detected ISP DNS or custom DNS? Might give cloudfare or quad 9 DNS a try for IPv4.
Auto-detect
202.142.142.142
202.142.142.242
Have changed the DNS to Manual and set it to 9.9.9.9
And Protection Engine is disabled currently? Yes
Jan 16, 2025Guru - Experienced User
Might set channels to 1, 40 and 69 for each of those frequencies.
Let us know if changing to a different DNS helps.
- kermitConsultJan 16, 2025Tutor
- kermitConsultJan 26, 2025Tutor
The changes to the channels did the trick
