kermitConsult
Jan 15, 2025Tutor
Re: RS600 Internet dropping out consistently
I am too suffering from this issue. Support desk did not have a solution. I am throwing the router in the bin. Brian Green [email protected]
- Jan 16, 2025
OK Changed the channels as requested, set the Primary DNS to 9.9.9.9
I will let you know how it goes.
Jan 16, 2025Guru - Experienced User
Might set channels to 1, 40 and 69 for each of those frequencies.
Let us know if changing to a different DNS helps.
kermitConsult
Jan 16, 2025Tutor
- kermitConsultJan 26, 2025Tutor
The changes to the channels did the trick
