IllLustration's avatar
Sep 23, 2024
Re: RS700 - Disable 5Ghz and 2.4Ghz band
I look forward to (the return of) control over individual bands. I can confirm that the schedule is a workaround for now albeit that it only allows you to turn off a band for a minimum of 30 minutes. ...
