coderbpv
Dec 27, 2024Aspirant
Re: RS700 - Disable 5Ghz and 2.4Ghz band
Has this been resolved yet? I have an RS500 and have the same issue with being unable to turn off the 2.4GHz band and I'm unable to use the scheduler to turn off a specific band. This is pretty u...
- Dec 27, 2024
RS500 supports the function to turn on/off each WiFi radio.
BH_C
Dec 27, 2024NETGEAR Expert
coderbpv
Thank you for the fast response and I see the setting, I was unaware there was a separate wireless settings area outside the top area of Advanced.
I was able to turn off 2.4GHz, thank you.
