Garyrh66
Jun 29, 2024Apprentice
Re: RS700 assigning same IP address to more than one device.
I am on firmware 1.0.7.86 and am seeing duplicate IP addresses for some devices also.
Garyrh66
I just rebooted the router and there is no longer any duplicate IP addresses.
BH_C
Jun 29, 2024NETGEAR Expert
We noticed this issue might happen in some cases. We have a trial firmware build that fixes this issue, please send me a private message if you would like to give it a try. Thanks.
- Garyrh66Jun 29, 2024Apprentice
I think I am ok for now since rebooting I have no duplicate IP’s. Thanks!
- Garyrh66Jul 01, 2024Apprentice
I have noticed something with this issue. When I am in the Web interface and make a change and then hit apply and it updates, and when I go look at attached devices that is when I duplicate IP addresses with some devices. If I reboot the router they get fixed and no more duplicates. Just wanted to bring this to your attention. Thanks.
- FURRYe38Jul 01, 2024Guru - Experienced User
Something that you might wanna try the beta FW as they seem to have fixed it. If interested.
Thanks! But it’s ok now and if I need to make a change I will just apply the change and reboot. I will wait for firmware to be released.
