JohnNadeau
Dec 29, 2024Apprentice
Re: RS700 assigning same IP address to more than one device.
Hi BH_C
Getting ready to try the Trial Firmware you sent me for the Rs700, thank you!
Do you know if the Rs700/BE19000 suffered from the same issue as the RS280S/BE9200 in the BPDU being sent out over the WAN Port, and if it has been resolved in the Trial Firmware I have?
As well, are there any Release Notes for the Trial Firmware?
RS700 does not have the BPDU issue. This is trial firmware, we don't have release notes for it.
1 Reply
- BH_CNETGEAR Expert
