Jpp993
Oct 19, 2024Follower
Re: RS700 Mesh Support
Hi guys, need some help here. We have 3 RS700’s. One is directly connected to the modem, and the other two are connected via Ethernet to other areas of the house. I’m not quite sure how to check if th...
ShadowMario3
Oct 19, 2024Luminary
Jpp993 wrote:
Hi guys, need some help here. We have 3 RS700’s. One is directly connected to the modem, and the other two are connected via Ethernet to other areas of the house. I’m not quite sure how to check if these are set up as AP’s/Mesh (if it exists yet) or standalone routers, but one of the issues we’re having is certain Sonos systems will show up on the app depending where in the house you’re at; kitchen (near router 1). Basement and living room (near router 2). Outdoor (near router 3). In typical mesh format you can see the entire sonos ecosystem.
How can we enable this as mesh via the nighthawk app? The website login doesn’t work anymore so the only way I can access the routers are via the app. Any help would be greatly appreciated. I’m not sure if I can return these as we’ve had them for over a year at this point, but it’s frustrating as I think we have 3 “different WiFi’s” even though we changed the SSID’s and passwords to all the same.
Instead of replying to a year old post, you're better off making a new one.
That being said, no, mesh isn't a feature yet.
