nylost
Apr 25, 2024Aspirant
Re: RS700 suddenly dead/brick
Same problem here. My router can not boot, as soon as I press the power button the lights start flashing, cevery second or so the same thing happens again, I can not do factory reset, I can not conne...
Apr 25, 2024Guru - Experienced User
Does a 30-30-30 reset help to recover the RS back to a setup condtion?
- nylostApr 25, 2024Aspirant
I also tried it, and it didn't work
- FURRYe38Apr 25, 2024Guru - Experienced User
I recommend you make contact with NG support then:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Then clicking on "Get answers about NETGEAR products before I buy" then clicking on "Networking for Home" then "Chat with us".
