nylost
Apr 25, 2024Aspirant
Re: RS700 suddenly dead/brick
Same problem here. My router can not boot, as soon as I press the power button the lights start flashing, cevery second or so the same thing happens again, I can not do factory reset, I can not conne...
nylost
I also tried it, and it didn't work
Apr 25, 2024Guru - Experienced User
I recommend you make contact with NG support then:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Then clicking on "Get answers about NETGEAR products before I buy" then clicking on "Networking for Home" then "Chat with us".
- BH_CApr 27, 2024NETGEAR Expert
Hi nylost, can you record a video on the router? starting from pushing the power button to turn it on.
Let me look at the video first. Then I may ask our support team to reach out to you for replacement. Thanks.
- nylostApr 27, 2024Aspirant
Thank you very much. Here I show the problem. https://youtu.be/nQq1lp1fBUA would be great if you could give me a replacement, I made the investment thinking in years of use and still not reached 90 days I think.
