Topology's avatar
Topology
Virtuoso
Nov 14, 2023
RS700 versus RS700S
NETGEAR references two different model numbers (RS700 and RS700S) for the Nighthawk Tri-Band WiFi 7 Router (see here).  What are the differences, if any, between the two?   Thank you.
  • BH_C's avatar
    BH_C
    Nov 15, 2023
    Yes, all the answers above are correct. RS700S is the product name or SKU name, its hardware device is RS700. The appendix 'S' indicates 1-yr Armor service is bundled. There are no RS700 alone products in the market at this point. If you look at the RS700S' device label, it still says RS700. I hope this explains.
